Have got a Potterton RS40 boiler used in the layout below as a fully pumped two valve system.
Was looking to have it moved into the loft to provide more space in the kitchen where its currently located.
The first question - can an old style boiler be moved the 8ft or would that be classed as a new installation and need a new efficient style boiler?
( I originally installed it, all the fixings are free to remove, it was commissioned by corgi eng)
The second point, if the pump , currenty in the flow out from the boiler, is left in the same position would there be any problems from over pumping into the expansion tank with the boiler being in the new position?
The minimum static head for the boiler is specified 3ft, the new location will give it 5ft.
