Currently we have freeview via a 48 band high gain aerial in the loft.
We get most channels despite having that thin foil backed insulation on the inside of the roof, but not the multiplex with Dave, Sky Sports News etc.
I want to get a company in to install it on the roof, as I don't want to do a Rod Hull.
The current analogue aerial (I don't use) is fitted on a pole at the top of the gable at the side of the house so its just above roof height.
Wire runs to the loft.
1 wire runs from the loft behind the plasterboards to the living room downstairs and a second to the master bedroom.
I may wish to run a cable to extra bedrooms a few years down the road.
I want to keep this setup rather than having them run wire down the side of my house.
Currently the aerial is connected directly using a coupler to the living room cable.
There is a very old 2 way booster in the loft, but using that makes the signals worse (presumably it's boosting the noise)
I want to keep costs down and buy most of the stuff myself as I don't want to pay 100s of pounds just to watch the new Red Dwarf specials on Dave.
Has anyone any advice as to what to buy and what to leave to the company?
I'm tempted to provide everything but the cable.
I'd probably buy from Toolstation, Screwfix or tlc-direct
Pole?
Brackets?
Masthead amplifier?
Masthead amplifier power supply (one that goes behind tv in living room)
Loft Splitter/Amplifier?
Current aerial: http://www.tlc-direct.co.uk/Products/MXD48.html
Pole?
Brackets?
Masthead amplifier?
