Moving plug sockets & add sunk in halogen lights to ceil
7 Aug 2007
Manchester
Hi all looked around but could find an answer to my questions
I would like to move my wall sockets plus turn them into double sockets instead of them being single ones , reason why i want to move them is they are about 1 meter high from the floors. Will this be easy for me to do i have got all the walls stripped atm and am going to be skimming the walls so i dont mind wrecking the walls.
my next question is ceiling lights the sunk in halogen ones.
right same again the ceiling is getting skimmed i can gain access to the top of it via the attic is adding 6 lights to the ceiling as easy as buying the lights and transformers cutting the holes in the ceiling and daisy chaining them from the wire that is going to the centre of the room atm?
Machead
sorry for being pushy but am i right in what ive said about?
when i say the wall sockets are 1M high all i want to do is move them down to the normal height.
cheers
No reason why you can't move your sockets and change them to twin sockets.
Don't quite understand what you are asking?
You can daisy chain your recessed lights if you want.
