Hello all,
I wonder if anyone can help. The Electrical supply to my house is currently an overhead cable attached to the chimney, this then comes down the chimney into the loft space, out of the loft space through the barge board. It then runs along the underside of the barge board along the side of the house, then the front and then along the other side on the house where it goes through the wall to the meter. Total distance about 16m.
Now I am planning a roof extension with removal of the chimney, I spoke with EON and they said they will not simply move the cable I will have to have conduit put under the road etc and a wall box to mount the new meter in.
So my question is, is it acceptable for the meter tails to run external to the building for around 16m? Or is there another acceptable way to do this?
Also how much do you think an electrician would charge for doing this? EON say I have to have an electrician present on site to disconnect the house and reconnect it when they have move/installed a new cable.
Rubbish diagram to show current installation.
thanks for your help.
