I am in the process of having a new supply installed to a cottage. Meter box is about 8 metres across my land from the footpath under which is the 240 volt cable about one metre from my boundary.
I will be supplying and installing the box for the meter, digging the trench and installing a duct with draw cord to the edge of the public highway. The DNO will extend the the trench from my boundary to the cable, supply the cable and make connections to the network cable and to the cut out in the meter box.
Cost quoted is £ 3,100 of which £ 1,300 is TMA ( Traffic Management Act ) charges, As yours is a private lane TMA costs may not be applicable. For connection of a supply cable to over head network the cost should be considerably less as the DNO does not need to dig other than a short length at the base of the pole. Do not take your trench ( at 750mm deep ) right up to the pole unless the DNO agree with this.
As mentioned before talk to your DNO about the best way to plan this.
