Moving Switch & Socket OK for DIY?
22 Jun 2010
Devon
Hello, we are widening an internal doorway and this will involve moving a socket and a light switch. The wiring for them both drops down the wall from under the upstairs floor and so it is just a case of moving the point at which the cabling drops down and then refitting the socket and switch.
It looks to me like this job in non-notifiable under part P, is that correct? and if so does that mean I am OK to do this work myself? I have done this sort of work before and thus am OK to do the job but am not qualified and wanted to ensure I was not stepping outside the current regs.
Thank you.
To keep within regs there are number of things to consider.
Firstly your ability to undertake and commission the task safely and that the work when complete is safe to use.
The cable route must comply to the permitted safe zones, any newly buried cable will most likely require the addition of RCD protection, if this does not already exist?
The work will be non-notifiable, providing the work does require a new circuit and is not within the zones of a bathroom. But under the guidance of BS7671 (wiring regs), a minor works certificate would be required on completion.
