Hello there,
We have a 1960's bungalow with solid concrete floors. We have a WC against an outside wall which we want to move through 90 degrees to an adjacent wall. The WC is against a false wall and has a vertical soil pipe straight down. We intend to remove the false wall for extra space. If we simply turned it thro' 90degrees the new WC would be 250mm out from the brick wall which isn't ideal.
We want to cut through the concrete floor and insert a new plastic soil pipe underfloor to connect with the outgoing drain closer to the outside wall.
I would like to know if this complies with building regs firstly?
Also a plumber I briefly spoke to said it depends on the floor damp membrane and how deep that is. How thick is the concrete likely to be before we find the membrane and is that something to strictly consider?
I haven't a camera at the moment to show you the loo but can anyone suggest a drawing website so I can draw it for you?
Thanks in advance to anyone interested.
Penny
Penny
