Hi
I have changed some halogen MR16 pin downlight sockets to GU10 sockets, changed the dimmer to trailing edge and replaced the bulbs with dimmable LEDs. Above the shower is a light on the same circuit which has an MR16 socket which I cannot change over due to its design so I have left it as is and changed its transformer to a dimmable LED one. That light and the other 3 run off the same dimmer switch however they dim at different rates (bought the same W bulb with different pins).
Is there anything I can do about this? I cannot change the whole extractor light system without huge cost and effort and I've looked into it - you can't buy a GU10 socket extractor light fitting or a dimmable MR16 extractor light. Sometimes the MR16 doesn't come on until you turn the switch up to full and then dim it. It is also brighter than the other 3 GU10s!
Any suggestions greatly appreciated! [/list]
To clarify, all 4 halogen bulbs were on this same circuit with their own individual transformers and all dimmed together.
