There used to be guidance in AD P to the effect that working to a standard of another member of the EEA would lead to compliance with Part P.
2006 version:
Not found in the current version, which only refers to BS7671.
Indeed, and I think that change is what has introduced some confusion into our minds, and into this discussion. One has to wonder whether the change was 'deliberate' (the references to the OSG and "IEE Guidelines" have also now gone).2006 version: ........................ Not found in the current version, which only refers to BS7671.
Not even BS7671 BAS? That looks like a British Standard to me.
Not necessarily, I would say. Although BS7671 mentions ferrous metal as an example material which it regards as being "sufficiently non-combustible" (which, as I've said before, sounds like an oxymoron!), it does not say that it is the "least non-combustible" (!!) that would be acceptable. In other words, despite that one example given, it does not say that a material which was "more combustible" than ferrous metal (whatever that means) would necessarily not be acceptable. There simply is not enough information.So, if someone were to use a CU that was acceptable in another country's national standard, given that 511 requires the designer to confirm that the level of safety is not lower than that for a UK product, would he not have to demonstrate that his CU was at least as "non-combustible" as a ferrous metal one in order to claim conformity of his design to BS7671?
No, it wouldn't.Would "manufactured from non-combustible material" in a standard applying to the construction of consumer units etc, with no definition of "non-combustible", no description of tests to demonstrate conformance etc, be acceptable?
No, they shouldn't.Do you think that people should have to imagine the presence of words not in a standard in order to understand what it means, or to make it workable?
Yes there is - BS EN 61439-3. However products to that standard are not considered adequate by BS7671.You say "confirm that the level of safety is not lower than that for a UK product", but there are no relevant standards which apply to UK products.
Although you have highlighted the word "not", does the "possibly" not also deserve highlighting? - i.e. through lack of information/detail in BS7671, we simply don't know?A consensus that a steel enclosure is necessary for compliance with BS7671 seems to have developed, and I am merely trying to point out that compliance with another country's installation standard would possibly not be sufficient.
Indeed not - but that's primarily because we don't know (other than for one example) what the "UK requirements" actually are!Perhaps, but we also don't know what is in the hypothetical "other country's standard" that might be considered a breach of UK requirements.
Well, it's only a finite number other other (known) standards.My point was that even where the UK requirements are clear, we cannot know if those requirements are met by some other unspecified standard.
Yes, sorry, I'd forgotten what the OP was about!if the UK requirements are not clear (which is the situation we're discussing)
It's actually what the entire 4 pages of discussion have been about, not just the OPYes, sorry, I'd forgotten what the OP was about!
