This should probably be in another place on forum, but wanted response from electricians... sorry
At work we have a Megger/AVO CM500 , which is pretty good tester in my opinion. It tests earth loop with just two probes (no neutral needed) ...only prob is we need another tester and the CM500 is quite bulky
was looking at
Megger MFT1500 Series but these have three probes (neutral included) for earth loop and other live tests.
Do you need to use all three probes for an accurate reading on earth loop?
Do you need to use all three probes for the tester not to trip RCDs ? It says that it only use 15mA current to do earth loop, so shouldnt trip 30mA whether you use neutral probe or not?
Anyone with these testers could give some advice? ... or anyone could advise on other Multi-function testers ?(dont like the idea of seperates)
thanks
was looking at
thanks
