Refitting my kitchen and have come across this slightly odd wiring setup.
A grid switch for the kitchen appliances is fed by a 4mm radial on a 32a MCB. From the grid switch there are 4 separate radials in 2.5mm that feed a single socket each.
Initial thoughts are it's bad, but as each spur only feeds 1 single socket, each one would be protected from overload by a max 13a fuse in the plug, and the 4mm is protected by the 32a MCB.
So while it's not standard, it seems everything is safe from overload, so is it acceptable? I don't want to rip it all out if I don't have to.
Thanks!
Thanks!
