Not mechanically or electrically what, EFLI?Surely then, that is not mechanically, and therefore not electrically, secure.
That's essentially what I was talking about - but not sure why you need to be able to remove the jumper, why not have it there permanently? I have a small number of these. I can't remember when/where I acquired them and haven't seen any advertised. I'm not sure who makes them (Says "RPP" and "Made in England"), and I can see no reference to BS1363 on it (only "PROV PAT"). Anyone know if anything like this exists these days (preferably BS1363 compliant/labelled!):What would be useful would be twin sockets with 1 terminal per conductor (each would have to have room for two though for spurs and for my wheeze).. .. with .. .. jumper bars between them (present by default so that you needn't use both sets of terminals if you didn't want to).
As I said - so you can extend a ring from there.but not sure why you need to be able to remove the jumper, why not have it there permanently?
Oh, I see (I think!) - do you mean have it configured as two single sockets (each with its own terminals), with a jumper to join them together for 'normal' use. Is that what you mean?As I said - so you can extend a ring from there. Break the link between the two halves, take a new cable from one side, off to the new sockets(s), returning to the other side of the socket.but not sure why you need to be able to remove the jumper, why not have it there permanently?
Yup.Oh, I see (I think!) - do you mean have it configured as two single sockets (each with its own terminals), with a jumper to join them together for 'normal' use. Is that what you mean?
I know.What I illustrated wasn't that - it simply has pairs of commoned terminals on an 'ordinary' double socket.
OK. Fair enough, a clever idea, but the additional complexity associated with the jumpers (there would have to be three of them) would probably make them unnecessarily expensive for routine use, since it would only be very very occasionally that anyone would want to take advantage of your 'ring extending' idea that it facilitated.Yup.Oh, I see (I think!) - do you mean have it configured as two single sockets (each with its own terminals), with a jumper to join them together for 'normal' use. Is that what you mean?
What do you think of it - and do you (or anyone) have any idea whether such things exist these days?I know.What I illustrated wasn't that - it simply has pairs of commoned terminals on an 'ordinary' double socket.
I'm pretty sure that nearly all of the Imperial PVC T&E I've seen has been bare copper.
Such a design obviously would need the internal connection between terminals to be able to carry 32A, but that didn't ought to be a problem for a solid bit of brass or copper. Are there reasons against this idea (other than cost) which I haven't thought of?
.. with ..
If the earths were combined and one extended the ring in the manner BAS has suggested, the CPC would change from being a ring to being a figure-of-eight.Only two would be needed; there's no reason why all the earths can't be combined.the additional complexity associated with the jumpers (there would have to be three of them)
That's functionally like the piccie I posted and ....That would effectively be the arrangement found on duplex receptacles in North America, assuming that you mean each set of terminals would be connected to one of the sockets. Normal North American 120V duplex outlets have two sets of terminals for the two outlets, but are supplied with solid straps in place between them. So you can feed in on one set of terminals and then continue to the next outlet from the other set if you wish.
...which is what BAS was hypothesising. However, as I said, I don't think the additional cost would be justified for routine use, although the (my!) idea of have 'twin single' sockets available would facilitate the occasional need to do what BAS was suggesting (or, as you've said, if one wanted to have independend control {or supply} of one half of a double socket).Or you can remove one or both straps to separate the two sockets for independent use ....
True but, in either of those cases, there is potential for confusion of testing (e.g. tests of ring CPC continuity at the origin of the circuit would be misleading.It would, but that would be no different from the same figure-of-eight arrangement which could result from extending a ring with metallic conduit (albeit that the c.s.a. of the conduit will be much larger than the circuit conductors).If the earths were combined and one extended the ring in the manner BAS has suggested, the CPC would change from being a ring to being a figure-of-eight.
