They could be trained persons, it might be that the trainer and / or the training he or she is providing is wrong.The sort of untrained idiots
And myself, I'll admit. I've had a lot of dealing with the so-called "Low Voltage Directive", which does start at 50V, and I would also have thought the definition of LV excluded ELV.thanks to stillp for enlightening us
Exactly.It's all relative. Use the correct terminology to talk to whoever you're trying to talk to. .... If you happen to work for a dno and are confused by posters on here then feel free to remember who you're trying to communicate with.
Yes, it's very odd, and I think a shock to all of us. Do you regard it as a 'mistake'?And myself, I'll admit. I've had a lot of dealing with the so-called "Low Voltage Directive", which does start at 50V, and I would also have thought the definition of LV excluded ELV.
"but i'm a bit worried how they can be safe if not low voltage [,] can these be left outside for good "
Can you answer that without explaining what low voltage is?
Could that be the fault of the manufacturers who label only 12V lights as low voltage? Why did that start?As BAS has pointed out, virtually no-one who communicates with 'buyers', all the way from supermarkets up to electrical wholesalers and lighting specialist suppliers would dream of interpreting a request for a 'low voltage' light (or fan or whatever) as referring to 230V.
Exactly.Easy. As they are over 1000v don't even consider putting them outside or anywhere near your property.
I imagine that it started (I would say very reasonably) when lights appeared which used a much lower voltage than had previously been used for almost all domestic/commercial lighting.Could that be the fault of the manufacturers who label only 12V lights as low voltage? Why did that start?
... and that would be because they did not know lamps were already low voltage.I imagine that it started (I would say very reasonably) when lights appeared which used a much lower voltage than had previously been used for almost all domestic/commercial lighting.
So, you are saying the correct wording should have been 'lower voltage' or 'extra-low voltage'. That may be the crux of the matter.It's not really any different from 'low fat', 'low sugar', 'low energy', 'low emission', 'low residue'.'low odour', 'low cost', 'low maintenance' etc. etc. etc. Whenever something appears which has a characteristic which is 'lower' than the historical norm, the word 'low' usually gets used.
No, I suspect it was originally derived from insulation standards, wherein it made sense to only separate voltages into LOW and HIGH, then later some people needed to deal with other measures for protection against electric shock, including ELV.Yes, it's very odd, and I think a shock to all of us. Do you regard it as a 'mistake'?
That's not the usual formula. Although one sometimes comes across descriptors such as 'lower fat', 'lower energy' etc, it is far more common for the worded adopted to be 'low'.So, you are saying the correct wording should have been 'lower voltage' or 'extra-low voltage'. That may be the crux of the matter.
Indeed, but I see no anomaly there. 'Leaded' means that lead has been added, so 'Unleaded' means that it hasn't. If it contained no lead, the term would probably be 'Lead-Free' (just as, for example, with sugar-free or gluten-free foodstuffs).'Unleaded petrol' means that none has been added. It does not mean it contains no lead.
Yes, but like the voltage, people don't realise what it actually means.Indeed, but I see no anomaly there. 'Leaded' means that lead has been added, so 'Unleaded' means that it hasn't.
Maybe, but those who know what"Unsweatened" means ought to also understand "Unleaded".Yes, but like the voltage, people don't realise what it actually means.
