Sorry if this is off topic but hope for a simple answer.
I have just converted my pushbike to an electric aided bike by changing the back wheel for a driven one, it has x4 12volt 7.2ah battery on in series (48volt) and works well, i have a 48volt charger which does the trick.
i have also planned to wire in a control circuit using a 12volt battery wired into a key switch which then energises a coil on a 180amp relay.
Now the way i want to charge this is using an old iec kettle lead this has a configuration on using the left pin as the 48volt side and the right side 12volt and the middle pin neutral.
I have the 12volt charger (400ma) and the question is:
Can i link over the neutrals into any of the chargers?
