Got back my homebuyers report for the propery we're thinking of buying. Out buyers have just pulled out so we've got a bit of thinking time, time for reflection, as Blair would say.
Anyway, here are the important point, those of you with experience, I wouold really appreciate your take on these things, are they serious as they seem?
It's a two stroey mid-terrace from about 1900, no cellars.
It also says, about the walls,
There has been some slight structural movement affecting the property with some cracking over the window openings at the rear and walls slightly out of alignment. There is some slight roof spread and the rear roof slope is uneven. The extent is not possible to determine without entering the roof void. There were no signs of any recent current activity and the risk of further movement takingplace is acceptable
There is wet rot affecting the windows and repairs, or replacements, are required. As mentioned elsewhere in this report, dampness was found and therefore, significant timber decay may be present. A more detailed inspection of the floor structure should be carried out.
The walls contain a bitumastic damp-proof course. It was not possible to trace this right around the property due to the mortar pointing.
We recorded high damp meter reading throughout the ground floor which possible have been cause by the failure of the damp-proof course and a more detailed investigation is necessary.
The walls may contain a finger width cavity.
