My Knob Is Jamming My Fingers!
7 Jan 2014
West Glamorgan
If that got your attention...
I've been hanging doors, and we've moved from handles to (door) knobs. All is fine inside the room, but because of the placing of the square hole that takes the bar that connects inside and outside, I feel the knob is too close to the frame and can catch fingers as the door is closed. I believe the latch is a standard size at about 65 mm long. Are deeper/longer ones available; or do I need to a) chill out about it, or b) go back to handles? Thanks.
that's an easy one.
you need longer latches. Three inches at the very least. You can get them up to six inches to match the style of lock often seen on Edwardian and later Victorian homes (it looks best on a traditional panelled door)
https://www.ironmongerydirect.co.uk...51-127mm-backset-satin-stainless-steel-393829 this sort of thing traditionally has a knob.
Ironmongerydirect have a good selection of tubular latches including long ones. The yellow Altro ones are delivered with a brass or other metal foreend depending which you order. They have a good strong spring and seem nice quality. There are various makes.
http://www.ironmongerydirect.co.uk/search?searchtext=tubular latch &fl=brand:altro
I got some to match my horizontal mortice sashlocks on doors not needing a lock.
They also sell a matching tubular deadbolt such as you might use on a bathroom.
The tubular ones do not require a huge mortice cut out of the door, like a sashlock does.
I have an 80mm on one door, it is not enough with a 55mm doorknob.
If you've already already cut the door for a 65mm latch then you'll be limited to how far back you can go without showing the cutting already done to the door..
Common problem, Ive had loads of customers wanting a knob rather than handle.
They forget a knob only works with a large set back lock positioned on a mid rail.
