my new dewalt 18v 1/2" router has succumed to social media
12 Jul 2004
Surrey
new dewalt
Dewalt DCW620NT
lovely lovely tool i love it buuuuttt its wrong
with a router you sit it in front off you
you go for the handles -----not right the angles wrong completely against what you expect
scratch head .... then discover its the wrong way round as you no longer work from the front off the router
you have to work from the back and its brilliantly set up for this and the only reason i can see is youtube and similar need the logo off the tool prominent so the user is second best :giggle:
i am just not used to focusing on the back off a tool with the ratings plate :unsure:
They should have a little DeWalt flag flying on the top of it, then it can be shown off from all angles.
Although if Nosey hasn't got his Gregorys on, he might try and drive his golf ball towards it.
new dewalt
Dewalt DCW620NT
Can it comfortably do a masons mitre on a kitchen worktop?
its 1700w with a powerstack battery a bit less with any other as in flexvolt or xr so should do it easily it does in fact have an approaching overload warning so you can reduce load a bit
as an aside you would probably need 2 or 3 batteries fully charged as a 5ah battery contains [18x5x60]5400wm so about 3 mins at 1700w
Blimey, 3 minutes... I will stick with my old corded Dewalt DW625EK. I only work in domestic properties, so I am happy to use corded 230v tools, and when it comes down to it, most of my tools are connected to my dust extractor. The vacuum hose is far more cumbersome than the flex.
iff you have a decent jigsaw that can cut within say 6mm off the line without wandering off you can greatly reduce the load and allow a single pass on the worktop and possibly well below 1700w load and maybe 45 to 80 seconds per side so a full mitre per battery
also you will get more cuts per worktop cutter
I have only done about 8 mason's mitres. Not sure I would be confident enough to use a jigsaw first.
indeed its a UN necessary worry iff you have the mains as an option when you only do a few worktops
but iff you can reduce the need from say 7x5amp batteries off grid for a kitchen to say 4x5 by reducing router loading then worth working towards
now often with jigsaws the blade can "fold over" under heavy load by fold over i mean the jigsaw at the surface the blade starts to go off line but right side off the line but the blade under the worktop can amplify the off line arc and go well into the danger zone[cut into needed worktop] now whilst this is not ideal in any way providing its the odd nick in the bottom surface that can be filled in providing the front face and clamping points have a flat face to fit together the odd nick in between can be filled
now iff it starts to fold over you need to backtrack and gently get back on line away from the fold over
now iff it starts to fold over again then you need to backtrack and start again
now this can often involve say a 5 to 10 degree angle on the machine to cut a fresh face say 2mm into the waste side before leveling out again
