I used to get very annoyed by photos in service manuals of a man in an immaculate white coat gently 'tapping out' something from a sparkling new (and clean) part of the car with a tiny rubber mallet, whilst the reality (after a few years dirt and rust) involved several strong men, a sledge hammer and all sorts of improvised presses and winches!
Ah yes, the old "it comes apart easily when it's new" problem.
Land Rover are good for that. One example is the speedo gear carrier which "just slides into" the transfer box, and according to the manual "just slides out". Not when the bit of aluminium that's been inside another bit of aluminium has been exposed to the elements for several decades it doesn't. And there's only a tiny bit actually exposed - but it does have a lip that can be used with a small pry bar to slide it out. Except that the lip breaks off - which is actually fortuitous since that leaves an "end" where (once you've removed the handbrake backplate) can be used to gently tap it round with a drift to break the stick and then it will lever out. When that's what happened last time I had to get one out - to replace the little plastic gear that when it wears out gives you (at best) an intermittent speedo.
And a mate used to work for a main dealer. He said owners would be horrified to see how their vehicles got treated in the workshop - like taking the "gas axe"* to a 60+ grand motor that's only a year old but parts are already seized in place
If only manufacturers knew the value of a tin of copper grease on the assembly line - though I expect they do and don't care about the cost of not using it on the assembly line
* "gas axe" - colloquial term for an oxy-acetalyne torch, a required piece of equipment for any garage for dismantling recalcitrant parts. Often makes the difference between "well that's completely f***ed now" and "ah, got the b***ard apart".
I rebuilt a gearbox once, and did not have the special tool to hold in place the 3 little spring loaded balls into the ring(s) (from memory) that kept things in the right places for each gear.
Ah yes, the synchroniser assemblies, aka synchro hubs - where you slide the outer ring off and the parts instantly distribute themselves to all corners of the garage, never to be seen again
I remember helping a mate with a mini gearbox many many years ago - he was into rallying. Fortunately he had loads of bits lying around so we could take another synchro hub apart, and another, and ... until we'd managed to keep hold of enough balls and springs to get a working set back together.
Mind you, I had that just the other day adding a pipe stat to the heating system at church. The 2" pipe is a bit bigger than the springs are designed for, so took a bit of pulling to hook on. I lost grip on one, and for a small boiler room, there seems to be no end of places for it to hide - I never did find it, and that's a nice shiny spring a few inches long.
