Polly1 said:Well I'm kind of coming to the end of the road on this one & tomorrow I'm shifting the sockets off the RCD & installing RCD sockets on the ground floor outlets close to doors (2 of them).
securespark said:Polly1 said:Well I'm kind of coming to the end of the road on this one & tomorrow I'm shifting the sockets off the RCD & installing RCD sockets on the ground floor outlets close to doors (2 of them).
That won't comply with 7671...
Polly1 said:Page 20 of the On Site Guide. RCD's required - (iii) on all socket-outlets that may reasonably be expected to supply portable equipment used outdoors.
The RCD sockets I've fitted are on the only outlets that would supply outdoor equipment.
No other point relevant to this property says that RCD protection is required.
This one is sufficient...The RCD sockets I've fitted are on the only outlets that would supply outdoor equipment.
Polly1 said:I took a voltage reading on the light fitting they complained was excessively blowing bulbs. I got the usual 240v reading when the light was on & a 12v reading when the light was off. It's a 2 gang light & when I alternated the switch positions, I got a 5v off reading.
You should find that the voltage drops off sharpish when the first hint of a loads thats not of neglidgeable impedance (like your digital volt meter) is appliedI guess when off, the bulb was still receiving 12v which meant that it was constantly on even though not illuminated at all times.
Pretty unlikelyI initially suspected that the light may have somehow been connected to a 12v transformer that is used in one of the bathrooms
but I took up the floorboards above the light & found 1 foot from the light fitting that the light cable was taped against 2 runs of the ring main.
I removed the tape & thought nothing of it as it wasn't taped hard & it was new wiring brown & blue. But later I checked the light voltage again & it was zero when off now including when I alternated the swicth positions.
What do you reckon? Could the magnetic field from 2 ring main leads cause a 12v charge on the light lead?
Not sure about that one, still looking for a bad connection IMHOBut I was happy that I at least had an explaination of why the bulbs have been blowing often.
But I also reckon now that I the problem with that charge in the wire & taped against the ring main, I guess occasionally there would be feedback to the RCD unit & the RCD tripping was to be expected?
