Name of Shower Part?
9 Mar 2020
Can someone help me naming a shower part? It's for an Mira Atom EV, and it's the white plastic screw connector that joins the shower hose to the outlet. As you can see I cross-threaded the thing and it pretty much needs replacing, but I can't find the name of it to search for.
Hope someone can help.
Outlet connector. You may need the year/model type etc, in case anything changed.
The shower came with a white plastic connecter screwed into the outlet. The shower hose was then screwed into that. The thread of this white connector is now shot.
I can only see what you’ve posted. Any other photos?
Thank you all for your help. Turns out I have the new model Atom EV and the outlet connectors are elusive to find :/
I would go direct to MIRA then, they should easily be able to supply part, especially if it's the new model. Just be careful when attaching a metal end onto anthing that has a plastic thread.
