need a quote
19 Mar 2007
hi guys..just need a rough idea of how much its gonna cost to change my boiler....ive got a biasi combi 24 se ..its rather old..i want to replace it in the exact same place with a more efficient worceter bosh or similar...might need to slightly adjust the pipe work....shudnt be too much...and the flue needs to go staright up through the kitchen roof...any ideas how much..including powerflush/...ta?
Your existing boiler is quite efficient, reliable and are totally repairable.
If you have money to spend use it to improve insulation as that will give you a very good return on your investment.
Replacing your existing boiler will cost about £1600 and give you very little improvement in efficiency, perhaps 5-10% at the most.
Tony
strangely i agree with the figure or £1600 based on a 28i junior or si and a vert flue!
If the current gas pipework is 22mm then this would be a decent price including a powerflush / magna clean kind of filter.
I would disagree with agile on fixing an old biasi! throwing good money after bad on a cheap boiler seems pointless. This year you fix a leak, next year an expansion vessel and then the year after another leak! Get your boiler fitted by an approved wb fitter and you'll get a five year warranty (next day service if ever req') details of fitters on their website!
I fit a lot per year (wb) and have less that 1% failure rate in the first 5 years. They will run at around 92.5 % efficient on high fire. Very reliable
If the only reason your changing it is 'efficiency' then I'd wait until next year.
I'd wait until the Christmas Rush is over, and Engineers are looking for a good earner.
We're all slowly getting busier now, with breakdowns etc. so I'd imagine you'd be hard-pushed to get a competetive quote.
Ball-park, anything from £1000 to £3000 would get a good system installed, flushed and good to go.
As mentioned, WB = 5 years Parts&Labour, Next Day Service.
Good luck.
looking at 1600 plus imo. any lower than that and i would question why the installer is doing it so cheap imo
"to be or not to be that is the question whather it is nobler in the mind to suffer the slings and arrows of outrageous fortune or to take arms against a sea of troubles"
shakespere :roll:
What about Vaillant or glow worm both come with five year warranty,the veissmann has one of the best no quibble warranties on the market
Worcester Bosch are pain in neck ,fine until they break down and yes as much as some people would like you to believe its a fact all of them will break down
The five year warranty from worcester especially for the budget junior models or their derivatives aint worth a carrot,that boiler is built for the cheap end of the market and only available in the Uk,if you choose their boilers then make sure its the CDI range
Also if you live in hard water area and wish to have water softner then theres no chance,because that aluminium heat exchanger will be destroyed by the salts
One should never ever believe all the marketing Hype!
