Need advice for garage
29 Jun 2024
Hello,
I would like some advice on renovating my garage.
It is a very standard garage, with dusty concrete floor, a main garage door and a back door.
I am looking to renovate it myself, however I have a few questions.
I want to add resin to my garage floor, and plaster board the walls, however I'm not sure what I need to do before I start these tasks.
My front garage door has gaps at the sides (see pictures), which allows air flow, but also water can get in when the weather is bad, also the rain can get under the main door when it rain quite heavily.
Should I seal the side gaps first and add a lip on the floor at the bottom to make this as air tight as possible? Or will this cause damp due to lack of air flow and trapped moisture.
Any help/advice would be greatly appreciated it :)
Thank you in advance,
Oliver
