Need advice- wiring room thermostat for use with tube heater
18 Sep 2008
Yorkshire
:?: Hi all, my first post on here (though have dipped in and out for a couple of years for advice), so be gentle with me!
I'm a fairly competent DIYer having undertaken a good few major projects in my life, including a kitchen extension a few years back from rewiring to plumbing and everything in between (before the reg's became so strict and complex :( ).
Anyhow, I'm looking to wire up a 120w Redring Suntube heater via a Sunvic TLX9201 room thermostat to provide controlled frost protection/background heating for the dry side of our aviary.
As I say, I understand the basics of electrics - but every time I look at the three wires of the tube heater and supply then at the four terminals in the thermo' - my mind just goes blank!!! I seem to have forgotten more than I ever knew.
Any help would be much appreciated
Lee
Oh, the terminals in the thermo' are marked as:
1 common
2 satisfied
3 demand
4 connect to neutral
Supply wires:
Live - terminal 1
Neutral - terminal 4
Heater wires:
Live - terminal 3
Terminal 2 is not used.
The two Earth wires connect together in a separate connector block.
Supply to 1 & 4, load to 3 & 4.
Don't forget to sleeve & join the earths.
Where are you taking the power from?
EDIT - too slow....
Thanks to you both, my cockatiels will are very grateful that they won't perish on those cold winter nights! :D
Now you've explained it, it makes perfect sense.
The supply is via an IP55 socket provided by a sparky who knew what he was doing so is fused and via an RCB etc
Cheers again guys
Lee
