Need fix-it for poor flushing, old (70s) toilet
25 Feb 2003
I have a toilet with an old, plastic cistern which apparently was quite common in the 70s - it's a thin cistern and the flush is a large push down button. The siphon has a lever mechanism that turns the downwards push into an upwards pull on the flush.
The flush is very poor on it now - repeated pushing of the button required to get more than a weak, partial flush. Full flush seems to happen by chance more than anything. Very annoying.
After reading some old posts it seems that replacing the siphon is what's needed. However I don't seem to be able to find this old style, lever mechanism tyrp of siphon. Any suggestions on where to get a siphon or how to fix this otherwise? TIA
Is the knob a rectangular one n the middle, curved on one long side? If so, Fordham Flush Panel - syphons still available.
Hi there, yes that is exactly it. Is Fordham Flush panel the name of the cistern itself?
So therefore I am looking for a replacement siphon to fit a Fordham Flush Panel?
Just make a new Diaphram for your existing siphon if u cannot find a source for a new one, easy job, just remove siphon from cistern, remove diaphram and use as a template to cut a new one. plastic from a 5 litre
oil container or bleach container etc will do the job
Thanks, I might try this. What does the diaphragm actually look like and where is it in the siphon mechanism?
Sorry.too thick..needs to be a fertiliser bag thickness IMHO :wink: Fkin Fordam flush panel :evil: used to be a replacemrnt for the old high level cisterns.where the pan was too close to the back wall..surprised any left
You will have to take the syphon out of the cistern.
The diaphram is at the end of a rod that your lever device pulls up. It is a thin piece of flexible plastic supported by a perforated/open plate. It has no doubt torn over use.
All you have to do is undo the connection from the lever to the rod, pull the rod and diaphram assembly out of the syphon chamber, remove the diaphram and replace with a similar one and reverse the process.
