Need Help to fix real wood floor...
9 Dec 2006
London
I just laid a real wood floating floor..... in living room and hallway without any transition and continued with the wood near the door....
everything looked fine initially... but then something went wrong... :roll:
the plank on the door which avoided me to put a transition is moving up and down as i step on it.... rest of the floor is solid and i am having no problems with it... its just that plank and its join with the row of planks in the hallway and the row of planks in the living room..
can anyone help me to fix this problem now as the full floor is done and dusted.. (or not!!)
Thanks guys...
G
Not exactly sure what you mean by 'which avoided me to put a transition in'? sounds like that board is laid on a part of the underfloor - in the doorway? - that is slightly uneven with the rest of the floor, causing the movement.
Best solution?
Cut the floor in the doorway, creating two seperate floors and install a wooden threholds (T-bar, twin)
