I have brought this light set which came with a transformer that you were meant to wire up.
I took down the old light and disconected all the wiring, probably my first mistake not noting where they went. Out of the Celing came three wires each had a red one a black one and a green one. I then connected all red wires together, assuming they were all live, and all the black, and earth wires togethers.
I then connected it up to my transformer, turned the power to the lights back on flipped the switch and blew the MCB (i think - sounded like i did). Though this could have been because i hadn't properly insulated the wires on the other side of the transformer and got a short circuit, or i messed up the wiring. Also the actual light was not connected to the transformer at the time, I hoped to connect up a current meter and check it was working before attaching the light.
I am not entirely sure what I have done wrong, if anyone could help i would really appreciate it. I have looked at other posts on this forum, though none seem to directly relate to this problem.
Thank you.
Thank you.
