Hello once again,
I have posted a topic about my Myson Apollo 30/50 on the blink. I think it's time to replace the boiler to avoid the annual few days without heating/hot water.
This time last year I had a chap round from British Gas to give me a free quote on replacing my boiler. He came in, took one look at my boiler and the flue system and told me - you won't get a new boiler to replace that one, you'll be better off replacing it with an electric heater and replacing all of your radiators with electric heaters.... This all struck me as rather extreme and being the slight pessimist that I am, I presumed he might have been looking for a nice big juicy commision on such a big job.
I shall explain to you the boiler and system that I have and maybe you can tell me what you think......
OK, it's a myson apollo 30/50 boiler, which heats water for my central heating and hot water - I do have an elson storage tank just below my water tanks and I presume this is what's used to hold and store the hot water.?? The big problem seems to be this - I live in a flat which is situated in a listed building. The flue for my boiler is a shared flue with other flats in my block, the flue runs through the middle of the block in between very thick brick walls(the building was put up in the 1740's and the walls are very, very thick) - The flue then goes out of some kind of chimney on top of the roof - I am led to believe that there may be some doors at ground level that have wooden slats in them in order top create a draught at ground level to take the fumes up and out of the roof, but I can't be sure if this is how it works. If my memory serves me well, the British Gas chap told me it was a 'C duct' or 'see duct' system, or something like that anyway and he told me that no boiler companies make boilers that work in this environment any longer and that my only hope was to find a second hand one, or replace the whole gas system with an electric one.
Obviously I don't want to have to go to the lengths of changing my entire system. Can anyone here shed any light on what kind of flue system I have and if it's possible to fit a new style boiler into this system - I must stress that as it's a listed building it's illegal for me to put an external flue on the wall so I have to use this shared flue. Surely this is not an uncommon problem, especially in blocks of flats?? Surely there must be some other solution? I should add that I don't plan to live in these flats for much longer than a year or 2, therefore a complete refit probably wouldn't make economic sense.
HELP!!!
HELP!!!
