Need some advice on my roof
11 Jun 2024
The roof on my extension leaks. Mostly down the lowest end of the roof but occasionally depending on wind direction in one of the corners of the velux window.
I'm almost certain the issue is the type of roof tile used, pretty sure it's a marly major. After a bit of research the minimum pitch for these tiles is 22.5 degrees . My roof is about 11 degrees .
Under the tiles is wet and the insulation under the membrane is also wet.
What are my options for an alternative roofing material. Obviously answers are felt or epdm . In an ideal scenario I would raise the lowest end of the roof(currently it only around 6.3 foot internally ant the lowest end ) by 3/4 brick layers and have a proper flat roof .and put patio door in .
For now I'm after relative quick fix until the funds allow for to do the above
You have an 11 degree roof pitch with a Velux and Marley Ludlow Major tiles?
First I'd question the Velux suitability for that pitch and it's debatable whether a tile exists for such a low pitch. A Ludlow Major is deffo not suitable.
yep. The extension was built before i bought it and I wish thrlese were the only 2 issues with it. Im just trying make it better. Like I said the long term plan is to raise the end and make it more of a flat roof.
im looking at possibly a rubber roof or felt roof short term . we dont get any leak on the velux often . It usually depends on the wind direction and I'm sure if more of a tile issue. I know velux are supposed to be around 15 degrees minimum.
Mendip 12.5 degree tile is the sensible approach. You should also change your skylight to the velux low pitch model 10-20 degrees
Question. Should this have been picked up on survey ? It was a level 2 survey.
Yes, a level 2 report would be expected to include comment of the apparent suitability of tiles for a low pitch. There are ways to use tiles below their guide pitch, but as this type of survey is visual only, there would be no way of knowing how the underlay has been designed or fitted.
Rooflight flashing/upstands are always a potential issue, as is underlay sagging at the eaves. You may be able to deal with these without a complete re-roof.
There are about five tile styles that will go down to 12.5°, but not 11.
ill probably just end up going with a felt or rubber roof
Forticrete Centurion Low Pitch Concrete, Crest G10, Crest H10, La Escandella Planum Interlocking Low Pitch Clay all go down to 10°, no doubt there are others.
There are other non clay/concrete tiles that will go down lower.
I looked at these a while back, I spoke to the manufacturer and he couldn't tell me why they were being marketed as 10 degrees over here.
You would have noted the design then .
For 10 degrees they are to be clipped not nailed .
Planum Low Pitch Roof Tiles | Only UK Supplier | The Roofing Merchant https://share.google/2wSA38gYkGJDMbogx
