    Dismiss Notice
Need to add crawl hatch to side of kitchen cabinet..
Discussion in 'General DIY' started by rarara, 11 Sep 2020.
  1. rarara
    rarara
    22 Sep 2010
    246
    Thanks Received:
    2
    Glasgow
    Country:
    So for various reasons :rolleyes: I need to gain access to a corner of our kitchen where there are units. I think the most straightforward is to cut a hole in the side of the (double, sink housing) carcass. By my calculations that might allow a hole of approaching 40cm wide by near 60cm. Is that generally considered large enough to stick a head and shoulders through to allow a bit of work to take place behind? And should leave the integrity of the side of the cabinet OK?
    Has anyone successfully done the same?
  2. foxhole
    foxhole
    14 Mar 2006
    17,110
    Thanks Received:
    1,955
    Kent
    Country:
    I’m used to have floor mounted boiler in kitchen corner, I put adjacent base cabinet on large castors instead of legs and just wheeled the entire unit out to service boiler.
    • Like Like x 1
  3. Sponsored Links
  4. conny
    conny
    30 Jun 2008
    13,354
    Thanks Received:
    698
    Suffolk
    Country:
    Were the castors the lockable type to prevent movement when in place?
  5. foxhole
    foxhole
    14 Mar 2006
    17,110
    Thanks Received:
    1,955
    Kent
    Country:
    Yes , though just put a couple of screws thru the side to lock in place.
    • Like Like x 1
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
