Hi guys
I'm looking to install a small water cistern into a loft space however the entrance to the loft is only 0.4 by 0.35 meters 350mm). its not enough to get the cistern through. Is their any way i can make this bigger without weakening the ceiling? I assume if i cut a joist, the ceiling will lose strentgh and i will be unable to walk on it? The loft hatch is currently inbetween two walls which are about 1 meter apart.
I need to increase the size of latch to about 800 x 800mm
here are some photos on the loft access and pics taken of joists inside loft.
Im a decent diy'er so was hoping with a bit of advice, i'd be able to safely carry out this work without weakening the ceiling. However I have almost no experience working on loft beams etc so dont really know what type of fittings are what, what different joists may be called etc!
But once explained i'm confident I can get this done myself
