Need to re-paint my flat roof?
3 Aug 2015
Hello all,
Around a year ago my garage roof was re-done. It was organised by the neighbour (joined garages) as he had a bad leak and the new roof consisted of osb boards with "liquid rubber and reinforcing fibre mat". I saw some of what was happening - the fibre was rolled out and the liquid rubber was in a paint form which was rollered out over the top.
It's remained watertight but I'm wondering if it would benefit from some other product being painted over to add longevity and improve the appearance?
I've noticed just after it rains at the base of the downpipe there is a light grey residue on the ground similar colour to the roof so I got up there today and took some pictures.
Any advice on this would be greatly appreciated!
Thank-you
P
If the roof is still watertight, painting is optional and is more about protecting the felt from UV than improving waterproofing. The greying is just surface weathering of the mineral finish, which is normal and not a sign it's failing.
If you do paint it, make sure the felt is sound first — no blisters, splits or lifting laps. Give it a good brush down to remove loose grit and any algae, wait for a dry spell, and use a proper bituminous or solar-reflective roof coating rather than ordinary paint. Two thin coats is better than one thick one.
The light grey residue at the base of the downpipe is most likely just washed-off mineral grit from the felt surface, which is also normal over the first year or so.
