Just after a bit of guidance/confirmation really.
I've got a Neff B1422N0GB/03 oven. On a whim we used the cleaning function, water in the bottom of the oven, switch it to auto-clean etc.
Since then it has been tripping the RCD as it heats up. The rear element seems to heat up, but I thought perhaps that was shorting as it heats.
I did initially think it was damp inside, but having left it with the door open for a day or so, the problem remains...
But, I then put the grill on instead and as that heats up it also trips, which made me suspect the thermostat.
However, having set the temperature to just below 50 degrees, by turning the temperature dial I can get the stat to flick on and off without it tripping out...
So now I'm a bit confused as to where the cause might lie.
Of course, if the rear element was on when the grill was in use, that might point me back to my original thought?
Can anyone offer any advice or pointers? What I'm trying to avoid is randomly swapping parts in the hope they fix it...
