My neff u1461 fan oven heats up, but keeps tripping the fuse.
When I reset the fuse and oven clock, it starts heating again straight away until it trips again at a higher temperature a few minutes later, never immediately.
If I set the oven to 200 degrees it gets there after tripping out maybe 3 times.
I removed the oven back plate covering the element and the element didn't appear damaged?
I then started the oven up without this back plate and the oven heated up to 200 degrees without tripping the fuse at all.
If I replace the back plate it blows the fuse.
Is it that the heat is affecting the resistance in the element and I should just change it for a new one?
Cheers
Cheers
