    Dismiss Notice
Neighbours rainwater running into public path & house
Discussion in 'Roofing and Guttering' started by Goobergrapejelly, 14 Sep 2017.
  1. Goobergrapejelly
    Goobergrapejelly
    14 Sep 2017
    2
    Thanks Received:
    Country:
    Hi, I am hoping for some advice. I am in the process of buying a house however I have noticed a potential issue with the neighbours rainwater runoff.
    The house I am buying has a narrow public pathway along the back of it. The neighbour has built an extension, the rainwater from the extension runs down the gutter but not into a drain - just straight into the path. You can't tell from the photos, but the path is reasonably flat, with a slight well and also a tilt towards the house I am purchasing. Therefore a lot of the run off will run right into the wall of my house and collect in the pathway. There isn't anywhere immediately obvious where the water could be redirected, and the path is council owned, so I am guessing it won't be quick or easy getting them to make a 'V' grove in the path to redirect the water.
    I am concerned this could over the long term this could damage my house.
    My house is the wall on the left in the photos
    Thank you in advance for advice
  2. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,383
    Thanks Received:
    1,895
    Hertfordshire
    Country:
    Where does the other gutter lead too?
    Andy
  3. Sponsored Links
  4. Goobergrapejelly
    Goobergrapejelly
    14 Sep 2017
    2
    Thanks Received:
    Country:
    The other gutter runs around their house but it's a higher level than the one that runs to the ground
  5. ^woody^
    ^woody^
    3 Sep 2006
    32,789
    Thanks Received:
    4,433
    West Mids
    Country:
    Tell the council
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
