Hi, sorry for another nest installation thread, but I couldn't find my answer in any of the others.
I have recently purchased a new nest thermostat and was looking for a bit of advice.
Basically, I have it wired in and connected to my heating and hot water (I have a hot water tank). When I call for hot water, it works as expected, i.e the boiler kicks in and heats the water. When I call for heat, the boiler again kicks in, however, my problem is that for my heating to work properly, it also needs to call for the hot water at the same time.
I suppose I could put a jumper between the switced live of the heat and water, however this would work both ways and my heating would come on even if I only called for water.
My boiler is a Potterton Promax System HE 24, and I simply replaced manual timers with the heat link.
Does anyone know of a way to have Nest call for heat and water simultaneously when I require heat, and then only call hot water when I request, or schedule, it?
Thanks in advance for any help.
