I’m not no, I’m hoping the routing per the pic makes more sense of that.Are you sure they’re all neutrals? Seems odd, as when switched off they would become live
In short - the existing room thermostats have a red and black cable, the black to go to the zone valves, the red seem to go up to the programmer - but changing colour to black as they do.
The other red cables that go from the wiring centre to the programmer, are all connected to the valves “boiler connection” point, with the only trace of the boiler being linked to those blocks being the fact a switch connects to both the neutral bank the boiler and pump does, with the red cable from the switch going to the central connector of those linked connections.
