Hi all,
Apologies another nest thermostat query re installation. Reading the other pages has been helpful and think I'm nearly there.
Current set up: from mains fuse box 3 core cable to isolation switch - then a Live and Neutral come off and go to control panel (currently centaurplus c27), a further live and neutral go to boiler via 5 core care, and lastly an earth goes to boiler and further earth to control panel.
On the control panel: L, N as coming off isolation switch, a neutral wire coming off and going to thermostat, grey wire in number 3 from boiler (call for hot water), brown wire from thermostat into 4 (call for central heating).
Wall mounted thermostat - Thermostat position 1 brown wire - call for heat into the control panel position 4, Blue Neutral coming off control panel to thermostat position 4, and lastly direct connection to boiler via a black wire in the boiler 5 core which is joined to a current carrying yellow/green wire located in thermostat position 3.
Using the nest wiring diagram:
- Control Panel Neutral Live get changed over to the nest Neutral and Live
- Jumper wires from Live to position 2/5 in the Nest
- Grey wire in position 3 in the control panel to Nest 6 (call for hot water)
-Then Nest T1/T2 position wired directly to Nest thermostat
My question really is about the call for central heating which will eventually go into Nest position 3. So current set up black wire directly connected to boiler comes to join in picture 2 behind control panel from which a yellow/green current carrying wire goes to position 3 in the thermostat, with position 1 in the thermostat then joining control panel position 4 the call for central heating. Can the yellow/green current carrying wire be connected directly to position 3 in nest as thermostat will no longer be needed?
Any help would be greatly appreciated
