nest thermostat
25 Sep 2021
had nest installed by an electrician downstairs and going to get one upstairs would it be easy to install it myself
Depends on setup and other things, like how handy are you? Can you work safely with electrics? Is there and existing one upstairs?
There is Nest Gen 3 and Nest e, which are you using? And it can connect as on/off or with OpenTherm, again which are you using.
Nest Gen 3 EU version is not that good, the US version can have remote sensors, but not UK version. But it can like only other switch, be used in parrellel with other switches.
OK, it is a pair of change over contacts, one for DHW and one for CH, the latter can connect to the boiler, or to a motorised valve, most thermostats need two or more wires, so adding a Nest e is easy, adding Nest Gen 3 may not be so straight forward.
