Can't find an identical problem, so here goes.
Nest v3 installed in the summer, by my local gas engineer. Don't want to bother him again as he took pity on us and charged us an unbelievably low price to sort out many issues left by a previous cowboy.
Heating and hot water are on a Y plan system, fed by a Worcester 35CDi. Hot water and heating come on according to schedule, and manual hot water boost and Nest room stat calls for heat as they should.
However, when the room stat is up to temperature, boiler continues to run, and radiators still get fed. Clicking of the relay in the heatlink when the temperature is reached, but still reads 10v at heatlink terminal?
If you then turn hot water to boost, and off again, the boiler shuts off and all is well again until the next schedule or movement of the temperature dial to call for heat.
Valve head? Incorrect wiring? Faulty heatlink?
Thanks for any help.
