We had our 18 year old boiler replaced last year after the annual service. Having had a big quote we got it replaced by a family friend. The official survey identified that our 'tank' is in fact a thermal store the guy who fitted the new boiler is having a few issues and I was wondering if there are any common problems with thermal stores which he needs to look into.
The issues we've had thus far are:
1) When the boiler was first fitted it constantly tripped with a "flow pressure" error. He's since replaced the pump.
2) Noisy system, banging pipes but also 'odd' noises from the boiler.
The system now gives a lovely warm house. However we still get a lot of noise. Also when the Hot water is on some of the radiators go cold. Additionally while the water initially comes out hot with the hot tap on hard it goes a lot cooler fairly quickly. With the shower on low it's possible to get a reasonably hot shower but if you turn it up all the way it's way too cold.
Also if I leave the hot water off, there's still hot water in the system so I can still run a bath. If I do this the noise in the system is reduced.
Any help gratefully received. The system was golden before we changed the boiler. Is there a chance that the boiler we have is no good for use with the store?
Cheers
Cheers
