I am proposing to run two T&E cables past an existing surface mounted gas pipe (22mm).
pg18 of the on site guide says that "Seperation of at least 25mm to be provided for domestic pipework up to 35mm. For pipework over 35mm then 50mm separation is required. The separation distance can be reduced if the gas pipe is PVC wrapped or a pane of insulating material is interposed.
I am therefore considering using PVC conduit to run the new cabling. I can obviously bend this such that I know I've got 25mm of clearance from the gas pipe where it bridges - and restrain it on either side. But its going to be very proud from the wall and hence not look very tidy.
Alternatively I could consider the PVC conduit to be a "pane of insulating material" and then only give a nominal clearance? but the OSG isn't as clear as it could be, and to me the word pane doesn't remind me of round conduit. I guess that the regulations are trying to prevent cables from rubbing against piping and causing damage to the cable - a phase conductor repeatedly arcing to a copper gas pipe would eventually cause a hole in the pipe and end in tears - or more likely would cause the RCD and/or MCB to operate.
I could obviously ask a gas engineer to visit and wrap the pipe with PVC, as it wouldn't be practical to do this without removing the pipe, so would have to be done by a gas safe engineer.
Anyone else got a view on this, I've searched high and low but surely has pipes and electric cables crossing paths is a common problem?
