Hi, I have recently moved into an older house (1977 ish) and I have just bought an electric double oven to replace the old gas cooker.
The house has GCH which has replaced the electric boiler(no longer exists).
Before I attempt to install the oven (with 10mm2 cable), I have a couple of questions:
1) When I moved the old cooker, i noticed a covered socket behind it, presumably where an electric oven had been installed previous to the installation of gas. There is also a 'neon' 45a switch? on the wall above the work-top which doesn't illuminate when switched (both are wired to something?) how would I safely test both of these to know what they are connected to? if they are live or dead? or if the light on the switch is faulty?
2) If I pull the 'cooker fuse' out from the CU, can I be sure that the switch is indeed on the cooker circuit and is dead? If I isolate the the whole CU, how would I know if i'm on the correct circuit or not?.
Probably getting myself into a fluster, but rather be safe than sorry, your input would be appreciated.
Thanks.
Thanks.
