New DIY installation nearly finished: Certificate (PartP)?
15 Apr 2004
Hi
I started rewiring the whole of my 3-bed house in Oct 2003 and have now nearly finished.
I have half a ring main to finish of and the sockets to put on (plus a couple of extractor
fans to wire up (wires are in place, fans almost in place)) Anyway, you get the idea.
I want to get an electrician in when I'm finished and ask him/her to inspect the work for
fifty quid or so and give me a test certificate saying it is all OK. This I want for house insurance purposes. because of PartP I feel I may now be running out of time. Am I?
I heard that one has 3 months to finish off works in 2005 since the Part P (party pooper?)
law came into effect on 01 Jan 2005. (and I have only weekends to work on my electrics.)
So, two questions.
Q1. Can I legally finish all or any of this work off? If so, how long have I got?
Q2. Do I need to finish before a certain date, e.g. March 2005, in order to be able
to get an electrician to produce a *certificate* for the work?
Any advice most welcome.
Thanks in advance
Yes, all work started prior to Jan 1st 2005 is exempt from Part P.
Q2. Do I need to finish before a certain date, e.g. March 2005, in order to be able to get an electrician to produce a *certificate* for the work?
Following from the above, no.
If Part P had applied you would have had to give prior notification to your local building control office. Mind you it's an interesting point abou the end date, but you're still exempt.
If you want to get clarification from here http://www.odpm.gov.uk/stellent/groups/odpm_buildreg/documents/page/odpm_breg_033480.hcsp feel free.
Great news. :-) Thanks very much for that. So, how do I go about proving that then?
Will the certifying electrician ask me for some kind of proof?
I also have a circuit for my garage power, but it only goes as far as the back door as
I have yet to buy some SWA cable to bury. Indoors cable is connected to the CU
as I am using this simple radial garage power circuit indoors whilst I finish of the
ring main. Is this garage circuit exempt too? (Perhaps that's stretching it a bit?)
Thank you.
I suppose if you contacted somebody now then you could reach agreement on that. If you left it until much later then you might have to go through the whole nine yards. (And yes, I'd go for the garage circuit on that one too!)
tricia said:
I want to get an electrician in when I'm finished and ask him/her to inspect the work for fifty quid or so and give me a test certificate saying it is all OK.
By all means ask.
Don't expect anbody to say "OK", though....
