I'm about to have ago at replacing my s****y interior doors with some new ones. Any decent tips. I'm going to take my time and kind of use the old doors as a template.
choose your new doors making shure they arnt twisted
leave them unwrapped at room temperature to acclimatise for a week or 2
check for twist or warp again
by all means use the old doors as templates but take notes of alterations where the door doesnt fit properly e g to tight here a 6mm gap here not parralel to frame ect and make adjustments accordingly
if the old door was a bad fit it may be re used so it may be worth checking the frame against a new door as this may be a better fit with less alteration
also if paneled or cheaper doors the lock may only fit on one style[edge] look on the top for l or h [for lock or hinge]
