New Element for a Whirlpool ADG7560 Dishwasher
Scottewing, I sent the info you need. To assist others with similar problems please let us know how this pans out.
Got a new pcb from an ebay seller. Fitted the new part and the machine sprung into life. Unfortuantely it died after about 30 seconds. I removed the new PCB for inspection and it has blown in the same place! :-(
I think enough is enough now and I've sunk enough money into buying a new element and a new pcb however there is clearly still something fundamentally wrong with the machine. Time to bite the bullet and buy a new one - something I should have probably just done from the begining!
Thanks to all who offered advice. A special thanks to zipper for sharing his wisdom.
Cheers.
What a bummer :(
If it blew in the same place there is still a short (or shorted component) someplace. It could be in the same location or it might be something entirely new. Incredibly bad luck all the same :( :(
I know this is an old thread, but registered to reply here to hopefully help other people who are googling this.
If you have tested the heater element using a meter (approx. 30 ohm is normal - mine was around 26) and it is within acceptable normal range, your PCB will probably be at fault. The reason why the previous poster Scottewing may have blown a second PCB is because when mine stopped heating up, I traced the wires back to the PCB and found the main wire going from PCB to heater element connector to have BEEN SLICED in half completely by the sharp edge of the metal door. These wires are supposed to be protected by a plastic enclosure which has disintegrated over the years. The wire would ideally need renewing. However, because there is plenty of it, I pulled the wire through so that I could solder join and heat shrink wrap it together, well away from the flexing hinge area. I then of course needed a new plastic protector from Whirlpool for £10.99...
http://www.4whirlpool.co.uk/dishwas...t.pl?pid=822181&path=600157&model_ref=2601413
My thinking regarding Scottewing's problem is that this live wire may have been touching metal (earth) and possibly blowing PCB's...
Hope this helps someone.
HOWEVER - please make sure you DO NOT OPERATE the machine again unless you have correctly fitted a new plastic protector and IF IN DOUBT - either renew the whole wiring harness (though I think you'll find this not economical) OR SEEK PROFESSIONAL SUPPORT. If you botch this repair, you could have a VERY dangerous dishwasher in your kitchen...
If you choose to replace a section of the wiring harness, YOU WOULD NEED TO USE THE SAME THICKNESS/GAUGE WIRE (you will need knowledge of SWG - standard wire gauge).
Important note - twisting wires and using insulation tape is definitely not acceptable. I chose to solder and use heat shrink wrap insulation.
** PLEASE NOTE - I AM NOT MAKING ANY RECOMMENDATIONS REGARDING REPAIR METHODS HERE (though I do recommend what is NOT acceptable practice) - AND AM MERELY POINTING OUT THE METHOD I USED TO REPAIR MY MACHINE AND HIGHLIGHTING POSSIBLE OPTIONS - IT IS UP TO YOU WHAT YOU DO AND I DO NOT ACCEPT RESPONSIBILITY FOR ANYONE EFFECTING THEIR OWN REPAIR BASED UPON THIS INFORMATION **
