- Joined
- 12 Oct 2024
- Messages
- 205
- Reaction score
- 10
- Country
Hello,
I had a new ensuite installed in a bedroom approaching two years ago. Just a toilet and sink. I paid a plumber to do the whole job. Toilet and sink wastes go through the outside cavity wall and into the soil pipe serving the adjoining bathroom (old cast iron soil pipe was replaced at the time with slip on plastic one). The house is a bungalow.
The toilet is connected to the waste using a 'question mark' type connector which achieves the right angle needed, and then does another right turn when it leaves the external wall into the waste pipe. Flexi type pipe is used through the wall. (See photos). Basically, the plumber ended up in a tight spot because of the way the toilet goes back to the wall and where the soil pipe is outside.
I reported to the plumber who did the work that the toilet wasn't flushing all that well within days of the job being finished. It clears 99.9% but always has this issue with a back wash of very small bits of ****. Several flushes usually clear it. Sort of. Weirdly, the bits can randomly appear after several days when you flush as though they are trapped around the waste connector. The flush isn't really abnormal but doesn't appear to be all that well designed and maybe the question mark connector reduces the efficiency of flow. There is no problem at all with the outside drains and, as I say, main load is flushed away.
Anyway, there was a back and forth with the plumber on WhatsApp and over the phone that went on for a long time. And I mean like it ended up being 18 months. He basically said his plumbing was fine, the fault was with the toilet, which was my fault because I chose it (even though all materials and labour were supplied by him and I simply chose one of the two he presented to me from his supplier). I disputed this.
Trouble is, it isn't clear whether it is the toilet or something else. Maybe the question mark connector? Maybe the flexi pipe? We could just replace the toilet with like for like (not many options available to fit the space), but since it doesn't appear to be damaged, this could be several hours work to achieve the same outcome and then I'd have an extra toilet I don't need.
After a tediously long time, we agreed that we would cover off all bases: replace the toilet, replace the connector with a proper right angle one, and replace flexi pipe. I agreed to pay for the materials for the sake of getting him to agree to do the replacement. The plan was to use a cabinet type toilet so we could bring the pan more off the back wall, create room for right angle connector and make it to the existing hole through the wall - all without losing too much space in what is a small room.
I sourced the new stuff, measured as required. Went back to him to agree fitting date and only got silence then, despite attempts to call and message. Complete waste of my time. A couple of months later, I changed the two 5 star reviews I'd given at the start to 2 star ones and explained why in my reviews. He suddenly got in contact and was complaining about my reviews... But didn't agree to fix his work, just went back to saying the same things from way back at the beginning. I wonder whether there is something about the job that he knows cannot be fixed?
I have since got a quote from another plumber to do the fix. He would want £250 and I will spent £300 on the new toilet, etc. I have also today noticed that the sink waste seems to be going uphill into the soil pipe outside so looks like that wasn't done properly as well. No doubt stagnant water sitting permanently in the pipe.
Questions:
- would you agree with my proposed way of replacing the toilet and connecting parts as the best means to addressing the toilet problem?
- is it worth making adjustments to the soil pipe, adding a boss maybe, so the sink waste pipe falls properly?
- bearing in mind that I gave ample opportunities to the original plumber to correct his work and must now pay out a further £550, plus whatever is needed to get a proper pipe run to work through the wall (he may have done this all wrong) and sink waste pipe... soil pipe amendments... maybe closer to £850... should I take this to a small claims court to reclaim my costs?
Thoughts welcomed and appreciated.
Questions:
