Indeed you did - but also bear in mind that it was not you to whom I was responding (or quoting) when I entered this discussion. If you look, you'll see that I was responding to ISWS15's apparent suggestion that one could/should 'go after them' simply because of the (possibly) incorrectly answered question. I say 'possibly' because, as we've been discussing, if the question actually did relate to 1/1/2005 (which I strongly suspect it did), then the presence of 'new' cable colours does not even prove that the answer was incorrect.Bear in mind I did sayif the EICR uncovers any horrors...
Kind Regards, John.
I was thinking along the same lies as BAS, if a test indicates wiring which does not comply with the regs and the buyer has to correct it before he can let out the property then there are costs incurred.
If the answer had been "yes" then the buyer may have commissioned a test before buying and taken the results into account when agreeing the price - we will never really know, but in answering "no" them the seller has misled the buyer. The outcome depends on whether the property is compliant or not.
