New oven rated at 2.99KW
7 Sep 2008
Kent
My wife has chosen a new oven (Neff) rated at 2.99KW. The specification says that it needs a plug and cable to be fitted by an electrician. I was wondering just how safe this would be if fitted with a 13amp plug as it's very near the limit. Will it get hot? (Socket is under kitchen unit in a cupboard). Would the 2.99KW be when the oven is using all functions and the reality is that it would rarely draw so much? We don't have a dedicated cooker socket, I'm afraid.
Yes, fit a plug. 2.99kW at 240V is 12.46A - not that very near the limit is a thing.
You are correct about the current draw. It will not draw the full amount for very long.
My voltage never drops below 240. (I have one of those plug-in testers).
Yes, but the Wattage and current go up and down with the Voltage.
The 2.99kW will only be correct at a specific Voltage. Does it not say what that is in the specifications?
mine sometimes does, in winter
but in summer, usually a bit higher
I had some other premises, among a few industrial units in a beachy district full of bungalows with solar panels, where the "resting" actual voltage was 230, same as nominal. IIRC the 3ph was 400. I presume because the solar panels pushed it up when the sun was shining.
A 13A plugtop (term deliberately used to annoy those who will be annoyed by it) should not be run with a 13A load for long durations. That said, it may be a total connected load and diversity may come into it also. That said, if it was suitable to be connected via a plug and socket arrangement then it would have been required by law to be supplied with a moulded plugtop fitted.
