New paint flaking off in one area
2 Dec 2013
Dear Experts,
I am painting the new plasterboard walls in my renovated living room ( https://www.diynot.com/diy/threads/insulating-my-ancient-living-room.648034/ )
Most has gone OK but there is one spot where the mist coat flaked off while I was applying the second coat. Actually the first sign of it being loose was before I started painting, so it is not the new paint that has caused it. Image below. Edit: the mist coat was done way back in January, if that makes any difference.
I have two ideas for the cause: maybe I got the mist coat wrong there somehow (e.g. bad mixing, and that’s a spot of undiluted paint). Or maybe there was some sort of stain on the plasterboard - some of these boards have been around for a while and got e.g. drips on them.
But the cause doesn’t really matter - the question is what I should do now. It’s a conspicuous spot next to a window, so it needs to look good when finished. Should I remove (sand?) all the paint to expose the plasterboard and then start again? Or should I paint over with something? I have some stain block.
Thanks for any ideas.
Looks like some kind of crud got in paint. Plastic or mastic like stuff.
Dig out. Fill. Paint
White paint with something gray that's cracked around edge. What's the gray crud?
The main grey in the middle is the exposed plasterboard. It has some bits of lighter grey on it that are probably the remains of the mist coat. Then there is the second coat, which is intact at the sides of the image, which curling away from the plasterboard where it has failed. You can see shadows of the curling-away bits - the light is from the bottom left.
