New ring main, cables attached under joists?
5 Feb 2005
I've an extension we are going to convert to a kitchen. This will be checked and signed off with building control, however, I have an electrics question.
There's one plug socket in there, wired to the consumer unit under the stairs, in plastic trunking running along the wall at ceiling level.
I know an electrician, who says if I do the hard work (lay the ring main, install the sockets etc), he will safety test it , connect it to the consumer unit and notify building control. Ditto with a radial for the oven.
The existing ring main (for the house) is loose under the floors, resting on the foundations with no clips.
1) Under the floor - can I attach the new cables to the side of the joists where the cables run the length of the room, and, run them under the joists (rather than drilling through them) when running the width of the room? Obviously clipping the cables so they're attached rather than hanging loose.
2) Where the extension joins the house, under the floor, the old exterior wall separates the existing kitchen and extension. Its a good foot thick. It would be easiest for me, access wise, to remove a few bricks down under the double doorway between the rooms, run the cables there, and put a small concrete lintel down to restore the original level. I'd end up with a brick sized hole. Is this an acceptable thing to do to run the cables?
3) I also need to run hot and cold water to the extension. Assuming #2 is acceptable, I'll need to run hot and cold water through the same hole. It it OK for these services to be run together? Any regs on separation or depth?
Thank you
That's ok, if he supervises all the work.
As do millions of others.
Ring final circuit; not ring main.
You can if you wish.
If you mean the wall is two leafs and a cavity, it would seem easy to remove one lower brick from each leaf.
I doubt any remedial work - lintel - would be necessary.
It would be alright if they are not wrapped together as is sometimes seen.
Why not remove another two bricks?
Oh - why not ask your electrician?
As said many don't bother clipping cables under a suspended floor. Rarely only a minimal amount of floorboards are lifted up, so not much can be clipped.
Also makes future alterations easier.
Don't drill any joists on a downstairs floor. It's pointless, weakens the joists when it's not even necessary, makes cables vulnerable to get nailed through, and generally a waste of time and effort.
Usually one whole brick can be removed safely, a lintel generally isn't necessary.
Hahaha I will. I'm at the "planning and trying to see how much I can do myself as money is tight" stage. When I get to closer to doing the work, he'll come over and discuss.
If you want him to notify the work then he should be involved in all stages.
It's no good you doing something he later disagrees with.
If you have already applied for Building Regulations approval, what did you say, or by default allow them to assume would be the way that you would ensure compliance with Part P?
If you've not yet applied, what do you plan to say, etc?
